1 - 6 of 6 Posts
Looking to pick up a med or large 7 Point frame. Prolly will go with the 17".
It's coming with a Marz Rocco WC w/300lb spring on it. Seems a bit low for me at 185lbs before gearing up...
I know the DW link runs smaller rate springs, but that much smaller?
What spring rate are you rocking, and how much do you weigh?
Still on Training Wheels!
175 w/ gear and running a 300 pound spring on my roco WC with full open compression and 170 in the bottom out chamber. Seems a tad light, but I think a 325# would be to much. FWIW I ride mostly DH and FR in Colorado so its very loose and rocky terrain.
I may look into what it takes to get a lower compression dampening shim stack from Marzocchi as I feel that the rear has the potential of being a little more plush.....but it is still light years ahead of the 5th element that I had originaly.
I weigh about 170 to 175 with gear and 300# is perfect with the Fox Van R. 30% Sag is highly recommended, nothing more nothing less, its butta!:thumbsup:
1 - 6 of 6 Posts
