I have a 2006 7 point 3. I am 190 lbs and the rear shock has a 300lb spring. It feels way to soft for me. I want to get a new spring, but I don't know how heavy of a spring to get. Any suggestions help. I usually only do 6 to 8 foot drops max.
check out this very good spring calculatordarenp said:I have a 2006 7 point 3. I am 190 lbs and the rear shock has a 300lb spring. It feels way to soft for me. I want to get a new spring, but I don't know how heavy of a spring to get. Any suggestions help. I usually only do 6 to 8 foot drops max.
The problem with the shocks from Santa Cruz is that they are valved for VPP bikes, which need a lot more compression damping than dw-link to deliver bob-free performance. The end result with the VPP shock on a dw-link is a bike that wn't be able to react to small bumps well. It will feel harsh.Rachid said:Hey, I had the same problem. So instead of spending 50 or 60 bucks on a new spring, I picked up a Progressive 5th Element shock from www.santacruzbicycles.com for $100 way better shock than the stock Metel RP on your bike, it will fit the 8.75 x 2.75 rear on the 7points. That's what i did and I'm much happier with my 7point.
cheers
You will feel great on a 350 lb spring. If you are a harsh lander, you could go for a 400#, but you are going to sacrifice traction in the corners and on climbs. With the 350 a good rider at your weight will be able to hit the big drops and have all the traction in the world.darenp said:I have a 2006 7 point 3. I am 190 lbs and the rear shock has a 300lb spring. It feels way to soft for me. I want to get a new spring, but I don't know how heavy of a spring to get. Any suggestions help. I usually only do 6 to 8 foot drops max.
First you should try a lighter spring with your shock. Preloading a lighter spring a few turns tighter to keep the sag the same as you like is not an issue if the spring is long enough (about 1/4 inch or more longer than stroke).motormonkeyr6 said:I also have an 06 7point3. The rear shox is alittle harsh for me. (at 105 lbs at 5'8") I dont exactly have the cash to upgrade. Its good for the big hits but the small stuff it almost feels like a HT (cause I dont weigh enough) What would be a good shox to get in the future? Im thinking used DHX, 5th element.
I thought about it but the METEL isnt a great shox to start out with. A spring is what, about 30ish? I mean yeah thats cheaper thatn almost 300. I might do that. I've been thinking about it.derby said:First you should try a lighter spring with your shock. Preloading a lighter spring a few turns tighter to keep the sag the same as you like is not an issue if the spring is long enough (about 1/4 inch or more longer than stroke).
If you get another shock I'd think the Roco World Cup would be smoother over smaller bumps than the DHX or other more platform type shocks. The Roco has great reviews here for the 7P and Sunday. Also your Manitou spring should fit. The Roco can be bought for about $285 from Alfred E. Bike and other's say they price match.
I really do not want to go air. But I think Im going to order a new spring. Does anyone know where I can get a 250?derby said:At 105 lbs, you will need softer spring for any other shock too, maybe 50# lighter. The stock is for average weight riders 145 - 170 lbs. Or go to air with your next shock.
I just got one from bikeparts.com and they had it to me in two days.motormonkeyr6 said:I really do not want to go air. But I think Im going to order a new spring. Does anyone know where I can get a 250?
If Im not mistaken all the bikes come with the same spring a 300lb. I look at bikeparts thanks.Free X-Rays said:I just got one from bikeparts.com and they had it to me in two days.
What spring comes stock with an large '06'? It was too light for my fat azz so I had to go stiffer. I'll check when I get home later and if it's a 250 I'll give it to you for free if you pay to ship.
Im just looking for a fork that can do dual duty both FR and DH. I ride more FR than DH but it needs to be able to do both. And for the money I dont think you can go wrong with a boxxer. Any other sugestions?wormvine said:I hear ya!
I don't even think a 200# spring exists. I found some 250# springs but not in the 2.75 stroke.
Boxxer's cool.
Boxxer Ride I heard is good. Adjustable travel as well. RS stopped making the ride but you might be able to find it still for sale like here:Im just looking for a fork that can do dual duty both FR and DH. I ride more FR than DH but it needs to be able to do both. And for the money I dont think you can go wrong with a boxxer. Any other sugestions?
