I'm gonna call marzocchi on Monday (and probably send my fork in) but I wanted to get the opinion of some of the experience Zoke users on the forum here first. I bought my 2006 66SL back in August from MHC, as most of you know it hasn't been ridden yet because my RFX build isn't done yet.
Anyway, it's just been sitting waiting for me to do something with it.
Yesterday my buddy (who just purchase one of these forks for himself) checked his out and realized that he's got a thru-axle/lowers misalignment problem that looks similar to these pics by Bikezilla. He called me right away and said that I should check mine, just in case there is anything wrong. Well, I pulled the fork and I don't notice anything too bad. But upon closer inspection today I notice that the axle is "catching" slightly as it's inserted throught the lowers. It doesn't appear terribly off, but not perfect either.
The bigger problem I have is related to the shock stroke. Even uninstalled, the fork is incredibly difficult to push down, I have to put much of my weight on it to get it to move (and I weigh a lot). It moves down pretty slowly, also. In addition, the return stroke takes about 2 seconds, much longer that I would expect the fork to ever take to rebound.
I tried multiple adjustments to see if something is out of whack (obviously something is), but can't figure out what could be wrong. The forks response is exactly the same regardless of the configuration I tried. Here's what I did:
I pumped the air chamber up according to the manuals specifications - 35 psi in both positives and 150 in the negative. I was using a high pressure (300psi) RS fork pump, so the #'s may've been a little off, but close enough for assessment. The test was tried with the bound turned all the way up, then all the way down...same response. Same test was done with the compression up and then down...same response. I did not touch the PAR chamber as it didn't seem that it would have any affect on what is happening.
Then we emptied all the air chambers and tried the same thing. The fork compressed a little bit easier (not much, though) but rebounded the same - excruciatingly slow. I obviously wouldn't expect the fork to act normally with no air, but I would expect there to be minimal resistance throughout the stroke with no air spring to support or resist it.
Curious little issue - using my fork pump I can only get the negative chamber to pump up to ~170psi. Even at this pressure (with the chamber apparently "full") the travel does not reduce at all. In addition, that negative chamber seems to fill very quickly when pumping it up. For example, each "stroke" of the pump adds about 10 psi. That seems like a lot. When I use that same pump to set the air pressure on my Reba it probably takes about 5 strokes (or more) to change it by 10 psi. Now, I understand that the air chambers in different forks (and even within the same fork) have vastly different volume capacities, and I'm sure the pump used makes a difference, but this seems a little strange. Anyone else have a similar experience with their negative chambers?
The whole thing just seems really odd. I've read many of the reports of twisted lowers and reports of initial stiction in non-broken-in forks. But what I've got going on seems excessive. I've only owned two other forks (a Zoke DJ and RS Reba), the Dirt Jumper came as OE on my HT and the Reba I replaced it with (that I purchased new) worked fine from the get go. I would've expected that the 66, even if it needed to be broken in, would at least be usable to begin with. As it is now, it doesn't seem to be.
If anyone can provide some insight I'd appreciate it. It seems that it's gonna need to go back to Zoke, if only to be checked out. I'm an idiot for not fully inspecting it earlier, since I received it way back in August and was fully aware of the potential issues with twisted lowers and such.
:madman:
Hopefully I'll be able to get this thing back and up and running in by the time I get the rest of my parts for the build. Thanks in advance for any replies.
