1 - 7 of 7 Posts
OK theres one thing that I dont understand (even with the manual). 66 light ETA:
eta, easy
air sag adjustment, easy
rebound, yip
the external preload in the right lower leg is a kind of hex-valve, bit in the manual is a kind of lever. Because theres no lever I assume I need a tool to move it...I tried a small hex and doesnt fit. How can I move the valve to make it click without braking anything?:skep:
Elitest thrill junkie
eta, easy
rebound, yip
What?
The lower right leg is the low speed compression adjuster knob.
PAMATRAIL said:
yes, but mine is not a knob is a piece of metal, like a valve. Am I missing something?
Probably.
I'd wager that the red adjuster knob has fallen off, there's a small allen bolt that holds it in place. Look for a small hole on the bottom of that "valve" where a small bolt threads in.
Discussion Starter · #5 ·
Im pretty sure the red adjuster knob just fallen of because I dont find any knob. Yes I can see the small hole....mmmmm Im going to see what can I do.
If theres no knob, how can I make it work?
1 - 7 of 7 Posts
