1 - 7 of 7 Posts
· Registered
RobsterCraw said:
I'm looking into the Marzocchi 66 Light ETA but I'm only finding limited info on the specs. Specifically, the Axel-to-Crown height, and how much the ETA drops the travel. On Speedgoat they list the AC height as being 555.2mm, can anyone verify this?
On mine I measured the AC (and possibly not the most precise measurement) at 545, 525 when set at 130mm travel. I find that when I use the ETA and compress the fork by weighting it it settles about 1/2 way into its travel. If you hit bigger bumps it will compress more but since I only use ETA on long, steep climbs I don't find it to happen much. Marzocchi's website list the AC as 538.5, 518.5 at 130mm.
http://www.marzocchi.com/Template/listSPAForkStatistics.asp?IDFolder=229&LN=UK&Sito=usa-mtb
· carpe mañana
How do you change travel on that fork? Or 130mm after you engage ETA?
_MK
· on a routine expedition
Those sound like the numbers for the Z1, not the 66. The chart you linked to shows the A-C for the 66 series to be 555.2 mm.
· carpe mañana
555.2 is for a 170mm
535.2 is for 150mm
The 66 appears to be 3.3 mm shorter than the Z1.
_MK
1 - 7 of 7 Posts
