650B in rear of C-dale Rise or Scaplel?
1328 Views 5 Replies 4 Participants Last post by  DaGoat
I'd really like to know. I think I'm sold on the Lefty fork (never ridden one). I'd really like to know if 650B will fit either the Rise or the Scalpel...
1 - 6 of 6 Posts
I tried a Neo in both of mine. No go. There seems to be more room diameter-wise in the Scalpel than the Rize. I'll just have to stick with a 650 up front. Look for an older alloy Rush or a Prophet if you want to run 650's at both ends.
i checked out a rize 3 tonight, could barely get a finger between the chainstay arch and the stock tire ... that would be a hot set-up if the 650b fit.
i specifically went to check out an 09 stumpy fsr and rize for possible 650b compatibility.
Was the Stumpy also a no go?
i would seriously doubt it. they only had the carbon version in stock, didn't appear to be much clearance (like less than a half inch between the treads and the bridge of the rear swingarm, not talking about the chain stays) ... the epic beside it had much more.
Anyone have a sanity check on the Cannondale (Rize) RZ-120? It seems from this shot to have a lot of room on the chain stays. Is it a diameter issue? Any RZ-120 owners running full 650B?
1 - 6 of 6 Posts
