onespeedpaul said:
.... bumping your seat a little more forward in the clamp, ...
Keen, compared to more smooth trail climbing oriented XC full suspension bikes with low BB's which are nearly 1 inch lower than your '08 RFX, your relatively high BB places the rider weight higher than a climbing oriented bike. On most full suspension designs, the higher rider position on a bike with a high BB exaggerates the rear squat and lighter front wheel when climbing.
As onespeedpaul mentioned above bumping your seat forward will help climbing. Your weight would be more forward while climbing and the front wheel won't be as light.
Changing to a longer stem as much longer as you move the seat forward would retain your reach, but it would also slow steering. An alternative to maintain familiar steering response is to lower your bars by moving stem spacers above the stem or using a flatter bar or stem with less rise or reversing the same stem to be negative rise, and bend your elbows a little more when steep climbing. Even without changing handlebar position, just bumping the seat forward will make climbing easier.
Additionally, here's some geometry to confirm your earlier post about the 650b front-only being near spec in steering trail. The '08 RFX has a pretty high BB at 14.1 with speced shock and fork (a good design for rough trail and the deeper sag of longer travel). Your short stroke shock with same i2i didn't lower the rear (and your reduction in sag actually raises ride time height in the rear), but the Pike is nearly 1 inch lower at full height than the speced fork so the BB is lowered to about 13.8 with 26" wheels, and steering trail much quicker than design spec. Adding the 650b raises the BB up to about 13.9 and the larger wheel geometry returns steering trail (and flop at low speed) to be very close to design speced responce.
Adding a rear 650b would bring the BB back up to 14.1 using the Pike fork and make the frame angles steeper which will reduce steering trail to be quicker steering than designed spec with your RFX with non-spec shock and fork. This should feel nearly the same as you were accustomed to with the 26" wheels.
No matter how you go with wheels, bumping the seat forward even just 1/4 in will have a noticeable effect on keeping the front wheel down while climbing. 1/2 inch or more forward would be a major help for climbing, but maybe affect overall handling more than you want.
The attached pic is clipped from the '08 Turner RFX web page.
