Here they are!
Here are a few pics of the wheels. I really have to thank my lbs ,Pedal and Spoke Ltd. of North Aurora,IL for all the help and the quick build once all the parts arrived. A great family run shop I have been going to for ten plus years. The owners son Ashton has become quite the wrench (even welds up custom frames). He has been maintaining my other wheelsets and bikes for years and he built this set for me. Chad helped with the parts pick. Thanks guys! Okay, sorry for the long shout out, but this shop deserves it. A bunch of us go there.
The wheels, blue ano Hadley hubs, 15mm front, 10mm thru bolt rear, black DT Swiss competition spokes, silver brass nipples, black Velocity Blunt 650b rims. Did a gorilla tape tubeless conversion, once around with 21mm wide, then once around with 1" (25.4mm) wide tape. I was purposely trying to build an inner lip to hold bead firmer. Stan's Olympic valve stem and sealant. WTB 650b 2.2 Wolverines. Tires went on very easy with just a little soap and water by hand, no levers. Used an air compresor to bead up the tires, very easy, then broke one side of bead and opened by hand, 1.5 scoops of Stan's sealant, aired them up and so far so good. Seems like a very solid seal. After I get out for a few good 3-4 hour rides with these on the Mojo SL, I will report.
