Been wanting to do this for a while as I thought this frame would make a great climbing trail bike. I have been on about 6 rides now and feel pretty good about the results. It climbs much better than my Blur LT 26/650B and descends nicely although not as well but thats to be expected.
The rear wheel does hit the front derailleur cable stop so I had to shim the fox air shock. It was easy once I figured out how to use a 1 1/4" hole saw to make the shims (See Pics) the cutouts were the perfect size at 1.1" I had to use 6 shims to get the clearance I needed so I lost 1" of travel. Still not satisfied though I am going to cut off the cable stop so I can reduce the # of shims.
No problems with derailleur clearance and the Wolverine tires helped because the side knobs don't stick out past the casing. I like these tires fast good grip a bit lighter at 680g and they air up tubeless so easy no soap required.
The BB height ended up at 13" with the fork set at 130mm. Just right for a trailbike. I know that is more than the SC recommendation but I tried 100,120 and 130 and it felt best by far.
Fox forks have low A-C height so I think that helped.
Enjoy the pics!
Enjoy the pics!
