What headset is everyone using on their 6.6? I just bought a standard redecer with a cane and creek headset, nonflush. Is anyone using a similar setup?
SAm
SAm
Yup.KRob said:Question on the FSA Orbit 1.5. Anyone having trouble with it loosening up and the O-rings at the top and bottom starting to work their way out? It doesn't seem like there's a groove or anything for these O-rings to run in so after a few rides they start bunching up and poking out on one side, especially the top one.
Oh. I see. This makes sense now. Yes I was placing the O-rings between the race and cups then tightening the headset. I did as you said and now all is good. Thanks.cuthberm said:Did you start with the O rings siting around the head tube of the frame, then after setting the headset and stem roll them into the groove that is left between the cups and the top cap / lower race. Sounds like you are starting with the O rings trapped inbetween the race and cups, when they work out your headset becomes loose?
