1 - 6 of 6 Posts
I have a 5th Element coil shock that I can pull apart beyond its resting length, for instance if I tighten up the coil spring while it's off the bike it doesn't compress the coil, it lengthens the shock beyond its stated "eye to eye" length. I cant imagine this is normal, shouldn't it stay the stated length when the coil is adjusted? If I pick up the bike, the swing arm pulls the shock apart enough that the coil spring is loose.
Any ideas? Thanks!
Discussion Starter · #3 ·
Bikinfoolferlife said:
Eye to eye shouldn't change like that with preload or not on the coil, let alone picking up the bike, something's broken...
I figured there was something wrong. I cant find my pump so I havent put any air in it yet, it has no air pressure right now, I am wondering if it is going to push it apart when I give it some air? Not having pressure wouldnt cause this. It seems fine other than it pulling apart.
Discussion Starter · #5 ·
Well, I feel more dumb than usual after realizing my error. I saved a bunch of shocks to my Ebay and when I finally bought the one I wanted and it was delivered I assumed it was the 8" shock I had chosen, I mounted it on my frame and that is when I thought I had a problem. It turns out I clicked on the wrong shock and ordered a 8.75" shock instead of the 8" shock I wanted. The entire time I was messing around with it I assumed it was the correct shock.
I will not make that mistake again! What an idiot! Once I adjusted everything it works fine, although my bike is now 1/2" taller than it used to be. It rides like a Cadillac but I think this shock is going on another frame. I only paid $35 new so I will keep it and order another one the correct length and use this one on a new bike I am collecting parts for.
Old man on a bike
You didn't mention that...I assumed it was pressurized, that would explain things. That's a big difference between an 8" and 8.75" though, be sure you don't have frame contact issues if you ride that...
1 - 6 of 6 Posts
