IFP/main balance for sag?
velomannr,
I'm new to 5th Air myself, and I'm still fiddling with the psi. I'm 150lbs + 10lbs/gear, and so far I ended up with 75psi/IFP & 95psi/main. I may go with 80psi/IFP, though I keep switching between 75psi/IFP ~ 80psi/IFP. Strictly sag-wise (25%~30%, preferably closer to 30%), I should really be at 90psi/main, but I'm so afraid to bottom it out. One time I even tried 80psi/IFP & 105psi/main just to experiment, and that was way too much for me. Anyway, I still can't seem to decide on this last bit of fine-tuning...
Hecubus,
I've read somewhere that, one would sit higher on a bike with a higher SPV setup, which can be compensated by lessening the compression/pre-load. What I read might've been about a SPV coil shock, but I wonder that maybe I can do so similarly by putting less main-chamber air when increasing IFP, when trying to achieve the same sag...?
If that were true... By having less air in main chamber for this purpose, on the other hand, I wonder if I'd bottom out more easily...? So far, I've used up 48mm of my 51mm full-spec stroke (94%). Have you bottomed out on the 5th air? If so, did you get a full-spec stroke upon doing so? I used to have an old Float R, and it
did give me a full-spec stroke upon occaionally bottoming out.
By the way, my leverage ratio is 2.5 (5" travel by 2" stroke), which is a good figure. Other than the leverage "ratio", does the suspension-linkage "type" (how the shock is mounted --- ie. horizontally mounted along toptube vs vertically mounted near BB) make a difference? (If so, how?) Generally-speaking, with my linkage "type" (pic below), should I be pumping more (or less?), when compared to other types, say, like velomannr's Racer-X's linkage type?
Thanks,
- PiroChu
