Found this tool in Home Depot... Great way to determine how different forks affect the head angle.
Hey Flipnflipnidaho said:you just have to make sure that you have a level floor and that your bike is standing up straight. The headbadge doesn't get in the way and if it does, you can always get some blocks so you can measure against the headtube instead of the badge...
The angle finder was less than $10 at Home Depot... The head tube is better as a frame of reference since some fork legs are offset at the crown..
The general rule of thumb is:GreenBonty said:Hey Flipn
Thanks for sharing. Now I need some education on the effect of HA on different riding perspectives. Like I know that when I added travel to my HT (changed HA), the handling slowed a bit. But I am sure there are many more aspects to why people preffer to build bikes to a specific range of HA.
Cheers
GB
In theory the head tube and fork are parallel to each other. The angle should measure the same. I figure it would be better to measure at the fork since that is what determines how the bike handles because the tire is attached to it.flipnidaho said:you just have to make sure that you have a level floor and that your bike is standing up straight. The headbadge doesn't get in the way and if it does, you can always get some blocks so you can measure against the headtube instead of the badge...
wrong. angle of the steering axis is part of what determines trail, which is one aspect of bike handling. On most bikes the steering axis is parallel to the head tube (some 1.5 head tubes with reducers can be canted to the steerer is not parallel to the HT, but you know if you have one of those).Nagaredama said:I figure it would be better to measure at the fork since that is what determines how the bike handles because the tire is attached to it.
The headset cups on my 575 (Cane Creek S2) are a bit different. The lower cup is flush with the headtube while the upper cup sticks out quite a bit. Also the headtube on the 575 is flared at the top. The headbadge was good enough for government work...Joules said:I'd think a better way would be to put a straightedge between the headset cups and measure the angle of that.
my fault, yeah the S2 uses a overlapping upper bearing cap to keep out water without really being "sealed" (whatever that means). I'm not sure what you mean about it being flared at the top - it just looks like it's externally butted to me (I know may ARC is, but it's butted at both ends), all the more reason a reading off the tube probably isn't that accurate - the inside of the head tube is parallel to the steerer (which is what matters), but the outside is not. If you have the stock thomson elite (not X4) stem you could put the clinometer on the back of the steerer tube above the head tube,flipnidaho said:The headset cups on my 575 (Cane Creek S2) are a bit different. The lower cup is flush with the headtube while the upper cup sticks out quite a bit. Also the headtube on the 575 is flared at the top. The headbadge was good enough for government work...![]()
