a bit of flex from the pivot
drjos said:
The design of the swing link or dog-bone requires that there be a pivot or flex point somewhere. The swing link controls angle between the shock and the seat stay and allows Yeti to tune the bike to the type of shock used.
David
Most modified singlepivots require a flex point. Most leave it out and completely rely on the the seatstay to bend themselves. A good example of this is the Fisher Sugar. This mono design is also called semi-pivotless (for all you old school suspension gurus out there). By not putting in a bushing, bearing, or pivot in there, you are pretty much guaranteed a rear triangle failure at some point in time.
You'll notice that the old ASR and Koko use a bushing, and a host of other monos have a sealed bearing in the rear.
Yeti has moved to the flex pivot because a bushing or sealed bearing is both over and under-doing it in their book. There is a very very limited amount of flex that needs to happen above the rear dropout. In addition, putting a bearing or bushing decreases the lateral rigidity of the rear triangle (a common cause of tracking/handling problems among the four-bar clan).
A sealed bearing typically is the smoother of the two, but the bushing takes side loads better. A flex pivot is the best of both worlds because it doesn't have friction between two opposing surfaces. It is also laterally stiff because the pivot is reinforced laterally, so iThe t is only made to flex in one direction.
Did I mention the flex pivot is also lighter?
The main disadvantage of the flexpivot is that they must be meticulously engineered and are more expensive to manufacture than a typical bushing or sealed bearing.
Everyone makes comprimises to be competitive in today's bike world. Yeti chooses to not comprimise in this spot. Like we've been hearing so much on this forum lately: "The devil is in the details." It's true. Give it a ride!
