If the $330 290g Syncros Hixon SL IC bar flips your trigger, consider spending 660% less on a $50 and even lighter 235g factory-direct version.
Link: AliExpress (multiple listings)
Weight: 235g (80mm stem, 680mm width)
Effective Stem Length: 80/90/100/110mm
Rise: -17-degree
Width: 660/680/700/720/740/760/780/800mm
Backsweep: -9[SUP]o[/SUP]
Stack: 40mm
Material: Toray 800
Color: 3K weave in glossy or matte, or custom paint
I mounted this bar in 80mm/680mm to my hardtail 29er and will be testing it throughout the season. It looks awesome and first ride impressions are all good!
The finish is very sleek. I went for the glossy 3K offering and have no regrets.
The weight is about as light as can be expected from the Chiner market. 235g for my 80mm/680mm bar rivals the equivalent 140g BXT 680mm carbon handlebar and 90g 80mm Kalloy stem combo I also ride.
If you're going integrated with this bar you'll have to be comfortable with -17-degree rise. There also are no integrated Chiner bars with short effective stem lengths like the Syncros Hixon, but conversely you can get much longer stem lengths than other integrated offerings on the market.
Going integrated can be scary, since you're eliminating bar roll (and effective backsweep) and won't be able to swap out different stem lengths. I have always ridden a -17-degree rise 80mm stem combo, so I knew this was something that would work for me. I overlaid my -17[SUP]o[/SUP] 90mm Kalloy Uno stem with a cut 700mm (~680mm) Tideace carbon bar with -6[SUP]o[/SUP] backsweep. There is a clear difference in backsweep, 9[SUP]o[/SUP] as advertised looks correct. This angle feels noticeably different, but in a good way. For me, it reduces thumb fatigue by allowing my thumbs to wrap around the bar at a more natural angle.
There are two bolts for attaching a front GPS mount, but I haven't used these (and don't plan to) since I go OTB often enough that I don't want to destroy my precious GPS.
A short-term solution for mounting my GPS was to install the base on the limited amount of straight tube near the brake levers, but in the long-term I'll mount the GPS onto the top cap.
The stack height of the stem is 40mm, by my best measurement, almost exactly the same height as my Kalloy Uno stem. The beefy construction at the steerer tube clamp means you'll need to tighten the bolts a little more than your average stem to achieve the same clamp strength.
As a huge disclaimer, I can't find any evidence that these bars have been tested to safety standards. Based on my experience, however I can say is that these bars are rock solid and very stiff. I have owned nearly a full dozen Chiner bars from different brands and cracked three, but this one is about as stiff as I have ever had, and I mean that in a good way as it still offers a comfortable ride. That said, this isn't a Syncros or a Syntace bar, and there is no manufacturer warranty offered, but you're also paying much, much less.
Pros:
Cons:
Rise: -17-degree
Stack: 40mm
Material: Toray 800
Pros:
- Lightweight and stiff construction
- Affordable price tag
- Dialed geometry
Cons:
- Integration means no bar roll
- No long straight tubes for mounting stuff
- Not offered in effective stem lengths <80mm
