1 - 6 of 6 Posts
No, that's not phonetic
I use that fork and love it. If the hose rubs on the crown it will slowly saw through the aluminum. Better to hold it away. Just run it up around the outside of the leg and onto the arch. Zoke's stupid hose guide pretty much guarantees the hose will rub on the crown. Duh.
Discussion Starter · #3 ·
thanks
can you send pics!
meh....
boxer6180 said:
what do you guys think about this air fork on a 5 spot and need some help on routing this front brake hose. marzocchi says that the brake hose should not touch the crown. any info will help
The way I route my brake hoses/cables is up from the caliper, around the inside of the lower leg to the front of the arch. A zip on the lower and the arch fixes the hose/cable.
Monte
meh....
tscheezy said:
Basically the same as Monte mentioned except I run mine up the outside. I'm "on the road" presently and cannot take a pic for you, so I got this out of the archives:
Eggzackery. I just come up the inside and onto the arch.
I'm not on the road, but I still can't get you a picture.
Monte
1 - 6 of 6 Posts
