Spent mucho time spec'ing this build. Wanted to run it through the Turner forum before giving the go-ahead to build it this weekend. Looking most for component quality issues... want to hear anything you have to say about the build. This build is not set in stone. Matter of fact, it's went through a major overhaul the past few days. The biggest change was switching from the Shimano XT Crankset to the RF Atlas Crankset. Other changes may be forthcoming....
Info! I need info!
* Main purpose: Fast and aggressive trails
* Trail terrain: Almost everything. 1-2 foot drops
*5'10"/225lbs.
* Frame Size:Large
* Frame Color (PC/Ano):Black
* Shock:Romic/650#spring
* Fork:Fox Vanilla RLC 130mm
* Brakes:Avid Juicy 7
* Cranks:RF Atlas AM Crankset 175 mm
* Shifters:SRAM X.9 ESP 9 spd triggershifers
* Front Derailleur:Shimano XT M761 Frt Der 28.6-34.9
* Rear Derailleur:SRAM XO ESP Rear Der Medium Cage
* Chain:SRAM Power Chains 9 Speed PC-99
* Pedals:Crank Bros. Mallet C
* Stem:Thomson Elite 100 mm 15 Rise
* Handlebar:EC 70 Monkey Lite 660 mm 1 1/4"
* Seatpost:Thomson Elite 330 mm length 27.2 mm
* Saddle:WTB Laser V Stealth
* Cassette:Shimano XT M760 9-Speed 11-32
* Headset:CKThreadless Headset 1-1/8
* Front Tire:Continental Vertical UST 2.3
* Front Rim:Mavic EX 823 36 Hole
* Front Hub/Skewer:CK ISO Disc Hub 36 Hole/Salsa
* Rear Tire:Continental Vertical UST 2.3
* Rear Rim:Mavic EX 823 36 Hole
* Rear Hub/Skewer:CK ISO Disc Hub 36 Hole/Salsa
* Seatpost Collar:Salsa Flip-Lock 32 mm
What do you have to say?
Info! I need info!
*5'10"/225lbs.
* Frame Size:Large
