Its that time of year to update the 5 spot with a fresh frame so I order one up (gotta go with the green this time) but hear that they are out of the HL version and only have TNT from this point on. There have been a lot of TNT reviews and they have all said good things about it but I want to test it myself. I want to evaluate it where I do a lot of my riding and can really concentrate on the bike. I've been riding this local spot for over ten years. Five of those years have been on an RFX and couple 5 spots. If there is a difference, I'm sure I will be able to tell riding here.
Here is the plan: take my existing HL five spot and run it through a battery of tests in all sorts of conditions: banked turns, flat turns, stutter bumps, braking, rock technical sections, drops, jumps, rocky climbs and steep, loose climbs. Then, with the help of my two buds, tear down the HL (blue) and build up the TNT (green). Everything will be exactly the same: same wheels and tires, tire pressure, fork settings, brakes, cranks and I will even take the same DHXA off of blue on put it on Kermit so we will have identical rear shock settings. Then take the TNT bike out and perform the same exact tests. To make it even better, we will videotape the test sections for all to see.
The big point of discussion about the TNT design is the braking and I want to test how active each of the two different designs can stay under bumpy conditions. To set up a test that is as objective as possible, I decided to try to do a brake to stop test. I picked out a section of singletrack that is hardpack and has rocks embedded in it, marked a line across the trail and make multiple runs at it. I have a cycling computer that will record my max speed on each run to record any variation in speed. Since I'm going down hill, the max speed should be my speed right before I hit the brakes. I will use the rear brake only and try to modulate as best as I can until coming to a complete stop.
Okay, time to ride. A little rain the day before but now its sunny which makes for some ideal conditions.
1) BRAKE TEST
First off is the brake test. Lets try not to over analyze this or armchair engineer my methods. Take this for what it is. A real person in the real world trying to see if there is a difference in performance! I took two runs with bike each as practice to get the dirt primed up and to get myself synced into the test.
HL: Distance to stop / speed
Run 1: 44' 0" @ 18.2 mph
Run 2: 40' 0" @ 18.2 mph
Run 3: 41' 6" @ 19.0 mph
Run 4: 40' 0" @ 18.2 mph
Now lets fast forward 3 hours to the TNT brake test:
TNT: Distance to stop / speed
Run 1: 40' 0" (didn't reset the computer DOH!)
Run 2: 40' 8" @ 18.5 mph
Run 3: 43' 1" @18.8 mph
Run 4: 41' 10" @ 19.1 mph
We noticed that the soil had dried out a bit more by this time of the day. But, as you can see, the ranges for each design were very similar (40 to 44 for the HL and 40 to 43.1 for the TNT). Could the rider tell any difference in the braking? No. Do the numbers support what I was feeling? Yes.
2) Cornering
Alright, put away the tape measure. The rest of tests are all about the ride! Lets start with cornering. The first type of corner I tried was a banked sweeper. I hit the turn at 27 mph on the HL. It felt good. Nice and stable, a little drift but very predictable. Same thing with the TNT. I hit the same turn at 26.5 mph. It felt like the good ol' 5 spot I have come to love. Next I tried out a tighter flat turn, the type where you want to put your outside down and countersteer. Couldn't tell a difference between the two @ 21 mph. Now we have a tight, downhill turn with some stutter bumps. I'm going to use some brakes over the bumps in the turn even though you're not supposed to. I hit it @ 23 mph on the HL and it felt good. I had a little drift but again very predictable. I hit it on the TNT at 22.5 mph and it felt good too. A little drift and some good exit speed.
Now, there is a tight turn at the top of the trail that is banked and you can get good traction in it. Good enough that you can go pedals level and really push the bike into the turn and get a pump out of it. I didn't have this section of my test checklist but I rode both bikes on this section. When I hopped on TNT and started making my way down the singletrack, I was instantly comfortable on the bike. It sure felt good, like my old Spot. When I came through this turn, I had the bike leaned over pretty good and I gave it a good pump. Wow, it squirted through that turn without any indication of wanting to go anywhere but where I was pointing it. Is the rear of this bike stiffer? It sure feels like it is.
3) Decending
Now lets do some technical decending. There is a 'waterfall' section that can be a bit rough. I hit it on the HL and bottomed the rear pretty good. The bike felt good and I felt in control the whole time. I hit it on the TNT and it really felt the same. The bottom out seemed to be a bit less harsh but that could be because of a slightly different line. Next up we have very steep roll in. You'll see it on the video and the video just doesn't do it justice. When you're rolling up to it, you can't see the actual face of it until your front wheel is already going down. Anyways both bikes seemed to handle this beast with equal aptitude. I extended the TST on my Z1 light to go to the full 150mm for this. Now we go over for a little drop action. It's a 3 or 4 footer to a nice tranny with a little gap you need to clear. Again both bikes handles this very well only bottoming out softly.
Up the road a bit we have a nice double jump that some of the local riders just put in. It isn't big but it is fun because it's right out of a turn. I again felt very comfortable on both bikes. Check out the video.
4) Climbing
Alright, the last part of the test involves climbing back up to the car. I choose two sections of single track to test on. One that is steep and loose. You have to be on it to clean it. Chest down and smooth with the pedal power in granny and you'll get it. I was able to clean it with both bikes. I didn't notice any difference in traction in the bumps or going over the loose rocks. The next section of trail is a long uphill with some embedded rocks. Its generally a 1-1 granny ring accent. I was paying attention to the activeness of the rear suspension while climbing and any pedal feedback. I was rolling over rocks and dumping the rear tire into ruts and holes. I could not perceive any pedal feedback in either design (it was a different story back in the day on my GT LTS and RTS …
. Now, the activeness of the rear seemed to be a little different to me. It seemed that the TNT was a little plusher while peddling over the rocks. Just a little more give than the HL. I'm not completely certain about this but it did feel a bit more compliant to the terrain.
Conclusion. I was a bit skeptical but I have proven to myself that the TNT 5 Spot is just as good as the HL 5 Spot. It felt great riding it on my home turf and I could not find fault with TNT and I found it to be better in certain situations. I was originally going to hang on to the HL spot for a while just in case but now I think I will put it up for sale now.
Read the test, watch the video and decide for yourself.
TNT HL Video
Note: The video will first show the HL (blue frame) then the TNT (green). The only exception is the brake test. The video got messed up with the HL footage (camera was recording when you thought it was off and vice versa - you have all done this).
S
1) BRAKE TEST
2) Cornering
3) Decending
4) Climbing
TNT HL Video
S
