Hey FM, are 5" RFX rockers the same as Spot rockers? Regardless, Spot rockers will work aces as long as you keep it to trail riding. If you can't dig up a pair of used rockers, I'd give Larry @ Mnt. High a call. Also, you probably have this covered, but if you're coming off of 6" rockers you'll want to throw on a lighter spring as well. Good luck with the event.FM said:Anybody got a set of 5" RFX rockers they'd like to part with?
I'm doing an enduro event later this summer (Cheakamus Challenge) and was thinking of swapping over the 5" fork & parts from my hardtail to the RFX, with 5" rockers, for it.
Dawgprimo said:There sure is alot of elevation gain on that ride!!!!
Are you also putting a different front fork on???
If I remember correctly I think your RFX had the F150.
(That sure would be alot of fork to push all the way to Whistler......)
Good luck on the race!!!!
Any luck in finding 5" rockers???
Maybe like Crashthedog said you could the 5-spot rocker.
