Have you shortened your brake lines?
If you've shortened the housing and not bled the brake correctly it can cause the brake to rub.........for instance too much fluid will not allow the pistons to retract completely which can cause a constant rub. You said you've tightened the rear hub........I've seen some of these things(mavics) repeatedly work loose. You might want to take some clear fingernail polish and dab just a bit on the axle between the lockring and the removeable axle cap, this will keep it from working loose in the future. If your caliper is dirty the pistons can get contaminated and not retract fully either, remove the brake pads and the rear wheel, squeeze the brake slightly so as to force the pistons to be exposed(but not too far where they pop out of the caliper). Take a little foaming simple green (prefferably the kind in a spray can) and spary the exposed surface of the pistons then wipe clean with a paper towel. Follow these steps again but this time put a single drop of chain lube on the exposed piston and using a flat blade screw driver(gently) push the pistons back in the caliper, repeat this 2 or three times. Reinstall your brake pads and wheel and you should be able to fell a difference..... assuming they were dirty to begin with. Ride On-
