Hey All,
I have a 5.5 Intense for just over 3 months now. I ride all mountain, occasionaly in bike parks, but usually quite rocky and/or rooty alpine trails. The bike has never been more then about 1 foot off the ground and I only weigh 160lbs so it hasn't had any serious abuse. I am loving the bike, but recently had the dreaded VPP creak start.
I took out the pivot bolts and the box link and cleaned the area around the bearings and pivot bolts as it says on the replacing the bearings guide on the intense website. I checked all the bearings that they rotated and all were stiff but eventually got all except one to rotate without much difficulty. One was still stiff and notchy but did move, so having read the thread about bearing myths and facts I decided that when the box link and pivot bolts were together it should be OK.
With everything clean and running relatively free, I greased and loctited the pivotbolts and reassembled the VPP link.
Now it says on the intense instructions that grease and loctite don't mix (obviously!), but if I grease the bolts and then insert them in through the slot on the boxlink and bearings some contamination is bound to occur. Is the loctite really necessary or do the two small allen key locknut's provide enough purchase to keep the pivot bolts from opening?
Secondly, I have reduced the creaking significantly by doing this, but there is a clicking sound from the area when I stand on the pedals and power. It doesn't seem to be there when climbing seated but only when I stand up and power. Does this mean I didn't grease the bearings enough? I put two lines of grease on the pivot bolts and then rotated them as I inserted them into the box link.
Should I have used more grease?
Is there other places that need to be greased?
How do I avoid contaminating the loctite if I use more grease?
I realise these are probably really dumb questions, but I don't want to keep taking the bike back to the dealer for what are probably very small issues.
Cheers for any advice anyone can give.
