Thanks again!I took a new measure today, and the widest point is at 33cm, wich means even more space, so I guess it will work
is the rear hanger / dropout part of the frame? in case of braking it can it be repaired?
I think the stickers are under the clear. That don't look easy to remove on mine.does the stickers come off easily of the raw?
I am running 1x10 with a 42 tooth cog, and once I got my chainline right, I can backpedal all day. I would think 1x11 would be the same.Anybody running 1x11 have issues backpedaling in the largest cog? I want to know if the chainstays are too short.
There is no reason to think a "short" chainstay would cause that, the differences in lengths of CS among bikes is fairly minimal, even between wheelsizes. The issue of the chain skipping down the cog is fairly common, and has a lot more to do with chainline. Bring your cranks inboard if possible. Otherwise, just don't backpedal while in the lowest gear...Anybody running 1x11 have issues backpedaling in the largest cog? I want to know if the chainstays are too short.
A short chainstay length will make the angles slightly more significant. But unless there's a several inch difference in chainstay length, it won't be enough of a difference to matter between any 2 bikes.There is no reason to think a "short" chainstay would cause that
nice!The party's just starting. Here's mine.
