use a 10T pulley
Do you mean B-Tension? (Ignore the letters on the image, its just the first picture of the b tension screw that I found)Elmo said:I tried to adjust the little screw but it didn't help that much.
Thanks for all the replies! Yes it's the B-Tension screw. It didn't help that much and I maxed it all the way in and then all out. I think I'll try the 10 tooth pully unless someone can explain way it won't work.amillmtb said:Do you mean B-Tension? (Ignore the letters on the image, its just the first picture of the b tension screw that I found)
Skip to 1:18
https://bicycletutor.com/adjust-rear-derailleur/
