Hey Fox fork tweakers, I need some input:
I'm riding a 32 Float 150 RLC (2011), and I'm finding it a bit wallowy - reduce the PSIs to get it plush and it becomes a melting marshmallow; jack up the PSI to get rid of the wallowy feeling and it becomes harsh. I also ride a 36 Float RC2 160mm. Barring the top cap needing to be replaced, can I drop a 36 FIT cart into the 32 chassis? Can it physically fit...is the FIT cart's diameter an issue? I don't care if there's a 10mm diff in travel since the (36's) FIT cart is a shim stack and doesn't matter if it sits in the first 10mm of its travel (AFAIK the FIT isn't a position sensitive damper).
Would this be a complete waste of time and money that would net me the same performance characteristics? My 36 doesn't feel wallowy, but that could be the larger air volume. TIA
