1 - 5 of 5 Posts
The older XTR cranks middle ring is a 34th and a weird bolt pattern. Where can I get a single speed 32T or even a 30T chain ring made? Please provide an e mail address if you can. thanks.
The 952 cranks are obsolete
Shimano made both four and five arm cranks and a SS for the 952. I know that for the four arm crank its very hard to find any rings other than Shimano and maybe Salsa which you dealer can order and probably just in the 24-34-46 configuration. The five arm crank has the 110 Bolt Center Diameter and has more available after market rings. If you have the five arm maybe your local bike shop can help. I didnt see anything at Boone with the 112 BCD that the four arm has. Nashbar sells a five arm spider that you could use to swap with the four arm.
1 - 5 of 5 Posts
