It's pretty safe to SAY it all you'd like, but not to do it.rixter67 said:If the seat post is 30.8mm, would it be safe to say that the front derailleur size is 31.8mm??
duc, the bike is a Giant Iguana Disc 2003. Do you know what the clamp size might be? I have been told 1 1/8" and another shop said 1 3/8"...... confusing.duc135 said:It's pretty safe to SAY it all you'd like, but not to do it.Unless your bike is made up of some exotic material that they can make the tube 0.5mm thick then, my guess is that you will actually need a 34.9mm FD clamp.
1-3/8 / 34.9mm, almost for sure. You can pull the seat post binder off and possibly find a number inscribed on it to verify (either 34.9 or 35.0), or if you have the old derailleur (I'm assuming you don't have calipers to measure with), pull it off and find the diameter stamped on the inside of the clamp.rixter67 said:duc, the bike is a Giant Iguana Disc 2003. Do you know what the clamp size might be? I have been told 1 1/8" and another shop said 1 3/8"...... confusing.
You can measure the exterior width of the seat tube with a ruler. Or use an adjustable crescent wrench as a caliper and barely snug it down on the outside of the seat tube and measure the diameter that way.rixter67 said:duc, the bike is a Giant Iguana Disc 2003. Do you know what the clamp size might be? I have been told 1 1/8" and another shop said 1 3/8"...... confusing.
Nice! I'm filing that one under "Useful Stuff".papajohn said:use an adjustable crescent wrench as a caliper
Not sure what the clamp size is, but if the seatpost is 30.8 then my guess is that the clamp would also be 34.9/35.0mm equates to 1 3/8". 30.8mm is just shy of 1 1/4" so there's no way it could be a 1 1/8" clamp. Just to throw a wrench in the works, I know Salsa also makes a 36 mm clamp, but that's a very rare size from what I've been told. "Usually" the FD clamp size is the same as the seatpost clamp size. Hope this helps.rixter67 said:duc, the bike is a Giant Iguana Disc 2003. Do you know what the clamp size might be? I have been told 1 1/8" and another shop said 1 3/8"...... confusing.
I would also have to go with the 34.9 / 1 3/8th clamp size. One of my bikes has a 30.4 seatpost with a 31.8 / 1 1/4" clamp. Another has a 30.9 seatpost with a 34.9 / 1 3/8" clamp. Just my 2 cents. I too like the crescent wrench idea, although I have a caliper to use.rixter67 said:If the seat post is 30.8mm, would it be safe to say that the front derailleur size is 31.8mm??
I have four bikes, by Titus, Ellsworth and Turner that all have 32mm seatpost clamps (for 27.2mm seatposts) and use 34.9mm clamp diameters for the FD, so I am not at all sure that your statement above is a good general rule.duc135 said:"Usually" the FD clamp size is the same as the seatpost clamp size. Hope this helps.
Duc
Like I said, I'm sure someone much more knowledgeable than me will put me in my place.papajohn said:I have four bikes, by Titus, Ellsworth and Turner that all have 32mm seatpost clamps (for 27.2mm seatposts) and use 34.9mm clamp diameters for the FD, so I am not at all sure that your statement above is a good general rule.
John
