I've run three tires Ghetto Tubeless (split tube method) and here are my results:
-Kenda Nevegal wire bead (OEM) worked perfectly, seated quickly with compressor and held air very good with my sealant brew.
-IRC Mythos II wire bead was a little harder to seat, and one blew off the rim at a little past 40psi. Once remounted and seated (not exceeding 40 psi to seat) the tires never burped. The sidewalls continually "weeped" a little sealant but seemed to hold air good.
-Stans Raven tubeless ready mounted up quickly and sealed up with no issues. Only got one ride (not a good tire for rocky areas) so far but great tire for hardpack and loamy trails.
I ride mainly on loamy trails that have much more root and log crossings than rocks so I'm not very hard on tires.
