I'm heavier than you and run less pressure than that when running 2.2 ACX's.tphenom said:I'm used to running 32-36psi in my 26" UST tubeless, now with the 29" Bontrager ACX 2.2 tires and tubes where should the tire pressure be?
I'm about 190 lbs rider weight. I figure somewhere around 40-45 psi on the 29" set-up. Hmmm?
In full riding trim (camelbak, tools, spare tube, etc) I push 280 lbs. I ride WTB Exxiwolfes w/tubes, and I ride at 35 psi on sand, rock, and hardpack too (but could go up on hardpack). No snakebit tubes to-date, so I figure you should be able to drop considerably if you wish to soften up the tail of that bike or just get better traction in the soft stuff.tphenom said:I've got a GF Rig singlespeed which, of course, is a hardtail and I ride it on less challenging trails than my geared hardtail and geared Ellsworth Isis. Still, I ride for the ascents, the rolling singletracks and the somewhat technical trail. I don't hit stuff hard or jump obstacles.
I'm running 35 psi now and feel I can go a bit lower.
You are in the ballpark. I always run the front 2-4psi lower than the rear. See if that works for you.tphenom said:I've got a GF Rig singlespeed which, of course, is a hardtail and I ride it on less challenging trails than my geared hardtail and geared Ellsworth Isis. Still, I ride for the ascents, the rolling singletracks and the somewhat technical trail. I don't hit stuff hard or jump obstacles.
