1 - 15 of 15 Posts
Hi Guys,
I have just today received my first 29er frame!
Now I need some rims for it. I have been looking a ZTR 355's as I have them on my 26er and they have been great for the last 2 years.
However, they are a bit expensive and wondered if anyone had tried the Sunn EQ23 or 25 rims as they seem to be reasonable weight and price. I would be looking to run tubeless as well so do these rims work or should I just bite the bullet and get the 355's?!
Any help much appreciated!
My experince woth the Suns was not positive. Spokes came lose... they would not stay true....
I bought Stans Arch and I'm dancing like Snoopy! I weigh 195 and aside from an initial truing of the rear after about 50 miles these are bulletproof.. and I am not gentle on them. I ride SW utah and the bike gets used 100+ miles a week.
Same wheel builder and known spoke tension? The Suns may have been too light for your use, but that's very typical of undertensioned wheels.
scsamoyan said:
no rimstrip just tape?
Yep, just tape. I've done this on my Mavic 521s on my 26" bike and also on some cheap rims I had laying around. I did use the wide tape though.
I weigh 200lbs, and ride a rigid and have not even knocked my blunts out of true, however they were built by someone I trust and rechecked after a couple of rides. The problem with the blunts is without the eyelets the spokes will come loose after a couple rides and if they arn't retensioned the rim will bend and then they will never be the same. I'm convinced that more than anything its the wheelbuilder.
Oh and I run my 29er down around 22psi front 24psi rear.
That's a pretty good argument for the benefits of a good rim design, since Sun actually manufactures the Stan's rim too
G
I thought that Stan's rims were made by Alex rims? No matter I am not a fan of there rims. I have used DT Swiss x470 with great success, they about the same as a set of Arches. I am now on Bontrager Mustangs, if you can get a set then go for it. The OSB eyelets and rimstrips make for a strong, light for a 195 pounder (840 front 940 rear with King hubs and Super comp spokes). They can be built lighter with different hubs easy.
non ust tires? and what you use for stem? thanks
I'm using Weirwolf LTs without issue. The stem is a regular Stans stem not the ones for stans rims. I'm using UST tires on my Mavic 521s with out problem too. When mounting up the weirwolfs on my blunts I deffinatly need to use a compressor but after I get them aired up I have no problems, On the trail I'll never be able to get them back up with a pump, but thats why I carry a tube.
Good question.... I just couldn't get the rear wheel to stay true and the cause was the spokes constantly loosened and it was a nightmare. I was truing the rear every 50 miles or two rides, whichever came first and that is totaly unacceptable. I had a (good) LBS true them and re-tension them more than once with the same results...
I was a novice rider and didn't really know much about line choice and such.. so I might have been a little hard on them but I wasn;t hucking off of ledges, drops etc, nothing outside of a normal service envelope for that design application.
1 - 15 of 15 Posts
