so im building up my first 29er, a Niner E.M.D., and had decided on a fox fork. originally, i was after the 100mm, but after having found great deals on both the 80 and the 120, im considering both of these as well. after reading the geometry on the niner site, they seems to recommend either 80 or 100, but no mention of 120. i know that 120mm 29er forks are relatively new, so i thought maybe this could be the reason, but im afraid to pull the trigger on one because it might wack out the geometry. i usually like the front end of my bikes to be a little higher anyway, as i dont typicall like that hunched over race crouch type position, and usually compensate with a longer/steeper stem. but if the bike were 20mm higher anyway, i might not need to.
so, if anyone has any thought/input id appreciate it!
thanks!
thanks!
