Fox 34 expertise, please
Suspension fork for a current Karate Monkey? I have a 2019 KM that I've ridden with a Vassago rigid and Reba fork in 100 and 120mm flavors. Most recently it's stayed at 100 mm.
Update:
Bike: current Karate Monkey can handle up to a 140mm fork.
New (to me) fork: 2016 Fox 34 Performance Elite, 140mm, lowers for 27.5+/29" tires, boost axle, Fit 4 damper.
I can ride everything just fine with little or no suspension, but I want to try this beefier fork. just not sure about the amount of travel. I can reduce the travel on the Fox to at least 120. If I want to go that route, does anyone know what specific air shaft from Fox I need?
What should I expect in terms of handling when I jump 40mm in travel? Can I adjust the settings in the fork so it rides lower in it's travel so the transition is not so harsh? or should I just embrace the long fork and send it, brah?
Update:
