OK, probably a lame question, but just how hard is it to put a bike together and DIY as opposed to LBS?? Thinking of building up a KM for my new fattybike, I mean clydesdale worthy bike. Only twist would be Reba and avid mechanicals.
It's not hard at all. Even cutting a fork can be DIY. Certain tools help in that operation as well as other things (BB installation, cassette installation, cable/housing cutter, pedal wrench, headset installation tools, etc...). You could always leave some of the more advanced things like headset installation and cutting/installing the fork to the LBS.bigdummy said:OK, probably a lame question, but just how hard is it to put a bike together and DIY as opposed to LBS?? Thinking of building up a KM for my new fattybike, I mean clydesdale worthy bike. Only twist would be Reba and avid mechanicals.
It's not really any harder than a 26" bikebigdummy said:OK, probably a lame question, but just how hard is it to put a bike together and DIY as opposed to LBS?? Thinking of building up a KM for my new fattybike, I mean clydesdale worthy bike. Only twist would be Reba and avid mechanicals.
Most of it I am pretty comfortable with and I have a torque wrench. The part that I am a little concerned about is "facing" and "chasing" the bottom bracket and some of the other areas where there could be paint. I hate to take business from the LBS, but the "goat" pricing on a put together bike is pretty hard to beat.JMKM said:It will save you time and potentially money. That is if you wreck some part. I would think that someone you ride with would be able to help you out. Probably only cost you a six pack.
I'm un-coordinated and I've succesfully built several SS bikesmiles e said:............anyone coordinated enough to ride a mountain bike should be able to put one together.................
I'm not sure if you're referring to Speedgoat or what, but if you are then they would surely chase and face the bottom bracket and headtube, respectively. It would be nice if other mail order outfits did the same, but they're not all on the same level as Speedgoat.bigdummy said:I hate to take business from the LBS, but the "goat" pricing on a put together bike is pretty hard to beat.
You could have an LBS with the proper tools do the facing and chasing as well. I paid either $10 or $15 to have them do that along with the headset installation. By the way, here in Des Moines - not too many places had the facing and chasing tools which sounds odd, but it is true. If you found an LBS - or Speedgoat as you mention - who can build it up with the parts you want for a good price and are happy with that choice, then it sounds like leaning in that direction might be the way to go for you.bigdummy said:Most of it I am pretty comfortable with and I have a torque wrench. The part that I am a little concerned about is "facing" and "chasing" the bottom bracket and some of the other areas where there could be paint. I hate to take business from the LBS, but the "goat" pricing on a put together bike is pretty hard to beat.
Bingo!Yunkie said:You can use several household things in bike-building. For example, instead of "facing" your headtube, just get some 100 grit sandpaper and sand the stupid paint off. If you're worried about "chasing threads" I've had at least a dozen mail order bikes, and that's never been an issue - just screw in the stinkin' bb. Next headsets are really easy. Just measure your ht length plus hs, go to hardware store and buy a bolt that's long enough to go through the ht with an inch to spare. Buy the matching bolt and four washers that are bigger than the outer diameter of your hs. Put the top or bottom of the hs in place with your hand and torque on the nut until it seats. Repeat with other cup. See diagram.
The pipe cutter does work, but it also flares the end of the tube. You may need to file on the flare for a while before the upper headset race will fit over the end. This why a shop will use a hacksaw with a guide that ensures a clean 90 degree cut.Yunkie said:There's a tool used in plumbing that is perfect for cuting fork tubes. It's a mix between a c-clamp and a pizza cutter. There's a threaded adjustable shaft with a pizza cutter blade on the end that cuts the steer tube. The inner wall of the clamp keeps the blade perfectly perpendicular to the tube. Here's a pic.
Right. You should file the end anyway - whether you use a hacksaw or a pipe cutter - once the cut is made. Both methods work just fine. I think the pipe cutters sell for about $10 (or you can go to the local hardware store and use their demo model for $0), a hacksaw can be had for $8 - 10 (as well as various other prices) and the hacksaw guide made by Park Tools is around $35 - $40. I prefer a hacksaw with a simple piece of tape wrapped around the steerer tube as a guideline (Mike T recommends a hose clamp). Just eye it up and cut straight. A piece of PVC pipe (1 1/4") is all you need to slam the crown race on that final 1/4". Or a 1 1/4" PVC pipe joint works as well and can be had for about 99 cents.Fattirewilly said:The pipe cutter does work, but it also flares the end of the tube. You may need to file on the flare for a while before the upper headset race will fit over the end. This why a shop will use a hacksaw with a guide that ensures a clean 90 degree cut.
BruceBrown said:Right. You should file the end anyway - whether you use a hacksaw or a pipe cutter - once the cut is made. Both methods work just fine. I think the pipe cutters sell for about $10 (or you can go to the local hardware store and use their demo model for $0), a hacksaw can be had for $8 - 10 (as well as various other prices) and the hacksaw guide made by Park Tools is around $35 - $40. I prefer a hacksaw with a simple piece of tape wrapped around the steerer tube as a guideline (Mike T recommends a hose clamp). Just eye it up and cut straight. A piece of PVC pipe (1 1/4") is all you need to slam the crown race on that final 1/4". Or a 1 1/4" PVC pipe joint works as well and can be had for about 99 cents.
Setting the star nut is a little more problematic when it comes to "home made" tools or methods. The proper tool costs about $14 - 15 and a wooden dowel can be the layman's approach. Both require eyeing things up to get the nut straight.
Whether you have the "proper" tools are use a makeshift "laymen's toolkit" work - the process of installation is all the same and requires care and patience. It's all worth it and is quite far removed from rocket science.
BB
Sounds good, funboarder1971. I splurged for the setting tool (it's not a Park Tools unit) last year for $12.99 at my local LBS. The LBS charges $3 to set a star nut. So far I have only set 2 of them (my REBA being one today) using the DIY method which means I will still have to set 3 more to "break even" with the local LBS. At my rate of purchase and upgrading, it will take another year or two to justify the expense of the tool. I did have the cassette removal tools (3 of them) and wished I had known your trick prior to splurging for the proper tool....funboarder1971 said:Since we're talking about how to use a tool incorrectly on your bike...
I've found that a cassette removal tool with the guide pin works well for setting the star nut on 1-1/8 steerers. Support the crown with a block of wood, put the guide pin thru the threaded portion of the star nut and a couple of hits with the hammer sets it in place...
but of course, you never heard this from me, right?![]()
Doesn't sound any more difficult than adjusting the valves on my KTM, or changing out the shock and fork springs on the same bike. Hate to take bidness away from LBS guys, but unless they can get close, I'll be mailordering and building myself. Thanks for the replies.BruceBrown said:Sounds good, funboarder1971. I splurged for the setting tool (it's not a Park Tools unit) last year for $12.99 at my local LBS. The LBS charges $3 to set a star nut. So far I have only set 2 of them (my REBA being one today) using the DIY method which means I will still have to set 3 more to "break even" with the local LBS. At my rate of purchase and upgrading, it will take another year or two to justify the expense of the tool. I did have the cassette removal tools (3 of them) and wished I had known your trick prior to splurging for the proper tool....
[email protected]
1 1/4" spec 40 pvc should be what you're looking for.Yunkie said:When installing the race, just get a piece of pipe from home depot that's the same diameter and use it as a slide hammer. Works perfectly.
