1 - 6 of 6 Posts
Ok,
I am building up an '09 Air9 as a 1X9. That said, I am using a WI ENO Crank Set and a Mid Cage XTR Rear D. With the new 73mm. Shell I am now in need of a new BB. So the 73mm/113mm. or the 73mm./121??? Basically, I am trying to provide my drive train the most optimal chain line (for a 1X9 that is).
Additionally, is the WI BB as good if not better than the Phil's Stainless I have been running (68mm.X113mm.)?
Need to know pretty quick as I am currently with NO BIKE!!! AHHHHHHHHHHHHHH! Kinda freaking out here. A little...
Many Thanks All,
PF
Discussion Starter · #3 ·
So...
Oliver said:
I would think either a 113, or a 116 Phil Wood should do the trick.
Do you think that the 121mm. is a little too long? The WI only comes in 113mm. or 121mm. I guess at this point I am leaning towards the WI 113mm.
Thank you for the reply I genuinely appreciate the info.
PF
1 - 6 of 6 Posts
