Stock?
My '04 293 didn't come with the Avid discs, so you are ahead there, with the '05, as well as with the Reba fork. I had an '03 Paragon and it came with the same bonti race wheels as my 293 has. They have been pretty amazing for durability: ridden really hard by a 220# 6'3" guy, not bad for 28 spokes. I just did have a failure of the rear rim. It tore in the brake track area, parallel to it, and these rims have never had pads against them. Pretty freak failure, no one at my LBS has ever seen anything like it. They are going to try to get Fisher to cover this issue, even though I am "out of warranty", since it is such a freaky failure that points to a material issue ( inclusion/void? - I'm a manufacturing engineer and it does happen).
Since the '05 has disc only rims you have no machined brake track area to split. I'm sure that the machining of the brake track set up a stress riser for the tear to start at.
I went to '99 lx 5arm cranks so I can run 20-30-42 rings and correct for the bigger wheels.
This bike will climb like mad in either the 20 or 30 front rings.
The one real performance advantage that the Marz MX Pro fork has is a lock DOWN feature that really helps keep the ft. tire on the ground on the really steep pitches. I'm gonna miss that when I upgrade the fork.
Other than the above changes the rest were ergo: extra long Thudbuster, Thompson stem, EA70 risers all to fit my freakish frame (36.5" legs). Other than the crankset the drive train is all stock and has been awsome.
Sorry Biz, but I cannot recommend your '03 frame as they had a lot more failures than the later frames and our thread starter would have no lifetime warranty as a second owner.
29erchico
