FortOrdDirt said:
Right now I can barely lean the bike over before the prowlers let out and they drift around a lot. As of now im assuming almost every tire im considering will perform better, as well as shed some weight.
Hmmm....that sounds odd. Are you tubeless? Low pressure? How long is your stem and do you feel like you have enough weight over the front wheel when you corner?
I've never tried a Prowler so can't comment on how it corners up front. I've ridden the IKON for a season up front an a full suspension bike and handling was predictable for XC racing. It's a great tire front and or rear.
BHohwel's too modest to mention the IKON's performance since he works for Maxxis. If you wanted to go through the Maxxis line for XC racing, the Ardent has the most bite, the IKON is next, then the Crossmark and Aspen (at least that's the way I've found them to perform for me). I've ridden all of those, but have not experienced what you mention that as soon as I lean the bike over the front lets out. Heck, I can lean over a Crow and other minimal tread tires without letting out with my tubeless pressures.
Never hurts to buy a bunch of tires, mix and match and have at it as conditions dictate.
BB
