Wouldn't quite call it a FATTY
jsord said:
Are these around? Who make frames/wheels/tires for 29r fattys?
Can someone direct me to a thread?
I have the Waltworks that CLONG mentioned (and thanks for the compliment!), and yes it was built for max tire clearance, but there's no way I could call it a FatBike, not with the current assortment of frames out there that accomodate Endomorphs.
I had the WW frame built up just as the FatBikes were emerging, and wasn't quite sure I wanted to venture that far, but have now found there's no comparison. FatBikes rule for the more extreme conditions. My WW is more fun once the snow gets packed a bit, as it has decent flotation, but as the conditions become more marginal it falters just by nature of its smaller volume tires.
IF 29er tires in larger sizes become available, I still have some room between the stays to accomodate, but it'll never match the current tire widths a dedicated fatty frame can.
CLONG, here's a few pics, raw frame, BB area showing what Walt did to give max tire clearance, some clearance shots, and the latest version of the built up bike. A WW fork will be next.
Frame arrived Aug/2005.
A chainstay yoke idea I've seen elsewhere, notably Kona. Walt asked if I was going to run a 3-ring setup, and since I said no, only 2-rings, this works.
Uma 50mm rims with large tires, and still a bit of room to grow.
And the smile creator! This is the only frame I've ever had custom built, and Walt nailed the dimensions for me. It's a ton of fun on our local trails once they get a bit packed, until that happens, the FatBike sees the action.
