I agree for BMX and the rear of DH bikesSprungShoulders said:They were thinking that 24's have definite advantages under certain circumstances, just as 29's do.
They actually work really well for technical riding. The 24" wheel lets you use a big tire without the diameter getting too big and heavy (try pedaling a 3" Gazzi on at 26"). Basically a 3" 24 has the same OD as a 26" 2.1. I can also testify that the 24x3" Arrow Wide Bite tires roll as fast as any beefy 26" tire I've ridden and that's saying something given their 3" profile. Pic is by Kristian.29Inches said:I agree for BMX and the rear of DH bikes
Heretic.DWF said:They actually work really well for technical riding. The 24" wheel lets you use a big tire without the diameter getting too big (try pedaling a 3" Gazzi on at 26") and heavy. Basically a 3" 24 has the same OD as a 26" 2.1. I can also testify that the 24x3" Arrow Ramp Bite tires roll as fast as any other 26" I've ridden and that's saying something given they're 3" profile. Pic is by Kristian.
Yeah, I feel like Sen. Salazar at a "Focus on the Family" group hug!s1ngletrack said:Heretic.
Damn - those are fightin' words (regardless of one's stance on the wheel size debate)DWF said:Yeah, I feel like Sen. Salazar at a "Focus on the Family" group hug!![]()
What? I put as1ngletrack said:Damn - those are fightin' words (regardless of one's stance on the wheel size debate)
That might be true if an when someone builds the fork you're talking about and a bike to go with it but as of now how are we misinformed? While the potential is there it hasn't yet been realized and until it is the existing bikes require a 5'6" rider to run a very short stem and suffer poor standover.Cloxxki said:Smaller wheeled bike fitting short adults better is only something temporal for front suspension bikes and doesn't even go for rigid bikes.
A no-compromise rigid 29" bike can "easily" be built for riders under 5'.
Limiting factor in suspension forks offered to us, is that even the most practical, the Marz, has only 43mm of offset. Unless offset grows along with the wheelsize, handling will slow down. Head angles therefor are now steepened, but with smaller frames that develops toe-tire overlap, scary stuff.
Something as simple as a 46mm offset suspension fork can bring the smallest possible no-comprimise rider height down by 4" over present 38mm off forks. See my signature.
Cloxxki said:In a DH race, my money is on 29" over 24"...
QUOTE]
C'mon, Cloxxki! Did you mean to say that your money is on the fact that the 29er wheel will fold in half before the end of the run? Or that you'll have 2 flat tires by halfway
29er wheels are too tall and have hubs that are too narrow to have the lateral strangth needed for real DH. IF hubs got wider ( and they do need to) and rims got stronger, then I could possibly agree with you for some courses.
But there's still be the problem of tires, because there are no large 29er tires, much less 29er DH skins. Lots of big tires are available for 24", and once up to speed with 8" of travel, some of the disadvantage of the smaller diameter is overcome.
29er wheels are great, but let's not overstate things.
I agree. Gazzi's = Slow rollers. The Arrows have intrigued me with how fast they roll and looking them again last night I think I've figured it out. The pics on the website don't show it, but the tire has a unique tread profile in that with normal pressures (~20 PSI) the tire rides on the center rows of knobs, which are ramped and about 2" wide. The rest of the knobs are offset and significantly below the centerline level so unless you're cornering or seeing a significant increase in ground pressure or on softer surfaces, the rest of the tire doesn't affect rolling resistance. This is obvious when looking at the tire head-on. Gazzi's have a much flatter profile and while they do have a much higher volume than the Arrows the difference in rolling resistance is really significant.sslos said:Disclaimer: I love my 29" wheel. You can have them when you pry them from my cold, dead fingers! Mike Curiak is my president!
Oh, sorry.
I used to race DH. And I had a set of 24" wheels to use with 3" Gazzis for a couple of courses, like Moab Rim in the Tour of the Canyonlands. They definitely have their place.
And with DH courses turning more and more into huge dirt jumping comps, they will continue to have their place.
However, I raced a lot of courses that I'd have loved to have had something like the Behemoth on.
Horses for courses, as the say.
the los
