I just received two of these 27W 1400 Lumen 3x P7 LED lamp heads last night.
11v - 18v 27W rated. I hooked up 4x Panasonic 2.9AH 18650 Li-ion cells in series and used a Magicshine battery bag. I use 4mm female battery leads and added a 4 cell balance harness.
How does it work?
210grams for the head+bracket+removable rear fins.
160grams for the head only (this will work nice on a helmet)
Blows the Magicshine P7 away - lots more penetration and more spread
Nicer colour than the Magicshine. Looks like around 5000K.
Looks like 3x the light output of a Magicshine.
Cheap - I got mine for $50 USD + $40 for the batteries - ie a great light for under $100 USD.
Has a bar bracket included
Has several light modes, very low (1W I think), medium, full, 0.7hz flashing, and SOS. I seem to recall it remembers your last setting (I will double check this).
Bottom line:
This has got to be to cheapest and quickest way in to decent lighting. I is much better than a Magicshine. You will also need a inline switch and battery balancing charger (I recommend the Turnigy 6S 6A - do not buy a clone).
BTW - RC users know that not balance charging will give only 100 charge/ discharge cycles or less, but balance charging and cell monitoring- ie properly looking after your batteries will give 500 cycles.
Sorry Mods - I got home late, so I did not get a chance to take photos - so I have posted the eBay ones here. There are also clips on Youtube - I will look for the links.
Note - currently not listed on eBay.
How does it work?
Bottom line:
