1 - 10 of 10 Posts
Discussion Starter #1
Hey everyone, I've decided that I'd like to get a hardtail to use for flow and jump trails and would like it to be a 27.5 to be more playful.
I know nothing really about hardtails so I'd appreciate some frame suggestions as I'm not sure how geo effects handling of a hardtail. Also how much do +size tires really effect handling? Ive tried them before and thought they were way clunkier than a normal 2.4in tire.
So far my top choices are the Banshee Paradox V3 and the Marin San Quentin 3.
I'm also looking at the Commencal Meta HT and Nukeproof scout but these seem to be using some older geos and have really short reaches. Numbers aren't everything though so I'm still keeping an open mind.
Does anyone have any suggestions on a frame thats aggressive and can handle jumps and drops?
I'd stay away from plus tires. A HT for use on DJ type features and for fun in general will benefit from a firmer ride. You'd be good with 2.3-2.4 tires. I'd look for a steel frame, if available. Aluminum will work, but fatigue may be an issue after years of abuse from jumps, etc. The shorter the chainstay length, the better. 27.5s are getting harder to find, so you're choices will be limited.
Sent from my moto g(7) power using Tapatalk
Discussion Starter #3
Have any steel frame suggestions that fit 27.5s?
Some good options in specs, geo and budget are the Marin San Quentin, Ragley Mmmbop (alu) and Ragley Blue Pig (steel). I feel that these bikes are very solid and have good price to performance balance. Hope this helps. Cheers!
Your bike sucks
This bike looks awesome but it seems pretty long which would make it feel big and sluggish on the trails right?
Not necessarily. Another one to check out is what I have: Chromag Stylus. Or maybe the Chromag Wideangle if the Stylus is a little too aggressive for what you want.
Discussion Starter #8
Yeah right now i'm stuck between the San Quentin and the Stylus. Both look super fun
I'd go Chromag. The Stylus is known to be built take whatever punishment you can put out.
1 - 10 of 10 Posts
