Hi All,
I picked up a 2nd hand Rockhopper recently (UK Spec - see bottom of post for details) and was wondering how wide I could go on tyres?
Currently it has bald 26 x 2.1 on it but crashed twice recently so need to replace. I'm not overly bothered by width other than the fact that there aren't many choices at 2.1 wide hence wondering how much wider I could safely go?
Thanks,
GC
FRAME New for 07 M4 manipulated alloy frame, butted ORE DT, disc only, forged dropouts w/ replaceable 98954020 derailleur hanger
FORK RockShox Tora 302 SL, 100mm, 32mm Cr-Mo stanchions, alloy steerer, mag lower, coil spring, preload adjust, lockout w/ rebound adjust
HEADSET 1 1/8" threadless
STEM Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise
HANDLEBARS Specialized 31.8mm XC Rise, 640mm wide, 8 degree back/6deg upsweep
GRIPS Specialized Enduro, dual density, Kraton
FRONT BRAKE Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
REAR BRAKE Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
BRAKE LEVERS Avid Juicy 3 hydraulic
FRONT DERAILLEUR Shimano Deore M-530
REAR DERAILLEUR Shimano LX
SHIFT LEVERS Shimano Deore SL M511
CASSETTE Shimano HG-50, 9-speed, 11-34t
CHAIN Shimano HG-73, 1/2" x 3/32" w/ missing link
CRANKSET Shimano FCM-442-8, Octalink Spline, 9-speed, replaceable rings w/ alloy outer
CHAINRINGS 44A/32S/22S
BOTTOM BRACKET Shimano ES-25, Octalink Spline, cartridge bearing, 68 x 118mm for 50mm chainline
PEDALS Specialized alloy 1pc, 9/16"
RIMS Specialized/Alex, RHD 26, double wall, disc w/ eyelets
FRONT HUB Specialized Hi Lo disc, 32h, CNC flange and disc mount, QR
REAR HUB Shimano FH-M475L, cassette, disc, 32h, QR
SPOKES 1.8mm (15g) stainless, black
FRONT TYRE Specialized Fast Trak, 26x2.0", DC, 60TPI, aramid bead
REAR TYRE Specialized Fast Trak, 26x2.0", DC, 60TPI, aramid bead
TUBES Specialized schraeder valve
SADDLE Specialized Body Geometry, MTB
SEAT POST Specialized alloy micro adjust, 30.9mm
SEAT BINDER Specialized forged alloy w/ Q
Thanks,
GC
