Ok so I had nothing better to do over the weekend and decided to try an experiment. I have read for years about people using 26" tubes in the 29" wheel with mixed success. I just got a set of RR (the new tubeless version) and was getting ready to set them via Ghetto. I found a set of Performance Lunar Lite 26 tubes in the cabinet and my curiosity got the best of me so I aired them up outside the tire to expand them a little then mounted the tire with the tubes and took them up to 35psi. Headed out to the trail to see how quick they would either pinch flat or just out right burst
To my surprise I put an hour in and nothing happened! So I dropped the pressure down to 30psi and thought this would surely be the end the experiment so I stayed close to the truck. Again no problem so I set the psi down to 28 (what I normally ride tubeless) and they worked fine.
My point to this rant is although I have run totally tubeless for the past 4 years it has always been a major PITA. The tubes come in at 92 grams on the scale and that is still 26 grams less than my standard tubless setup.
I'm far from sold on this concept but I am going to keep riding this setup just to see what the limitations are.
