1 - 9 of 9 Posts
J:
Want wider rims to get my 91 Trek on the beach:cool:
Swapped some rims off my 80's Motiv and put 2.4" conti TK... inside width for those are @25mm and the sleeve is about done, probably need wider for sand...guessing IW over 35mm is needed for the sand near the watter?
*the trials rims that I know of are upwards of 6 hundo...anything exist @ 550 grams:confused:
J:
Discussion Starter · #2 ·
J:
Discussion Starter · #4 ·
i35-40 near water line but in soft sugar sand no go, you need i50's or wider.
Thanks for the heads up!
Now I have some info to run with...from what I've seen as far as availability, widest ones are @47mm and there are 5-6 to choose from(black) and only 2-3 silver. These all seem to be measured using outside width
G
sure, many more folk on here with full fat experience that hopefully chime in with 3cent. Will this older trek handle i35 or 40's with the right tires??
J:
Discussion Starter · #6 · (Edited)
Tread clearance wise, the rear end will get the firmer implants. Brake posts are well over 50mm wide in the fork, much wider in the rear.
*EDIT*wow, that Jitsie black ano is an extremely tough finish!
J:
Discussion Starter · #9 ·
Need to find time to build, these are going to be fun:cool:...here's a pic for now
When I bought em', there was also some mention of the spoke hole location/ rim profile...see how it goes, I'm wondering if there's maybe a different type of nipple now that would be easiest for these
1 - 9 of 9 Posts
