1 - 20 of 20 Posts
I've searched all over about this and the only definitive answer out there is that you're better of just getting the proper fork for your wheels. If you're going 34 anyway I don't see why you wouldn't want the 27.5 version? The reason I was curious was because I'd kinda of like the more beefy 36, so I was trying to justify stuffing my 650b in a 36. From what I gathered that plan would work, but depending on tire choice there's a decent chance I would need to rock a 10mm travel spacer. That isn't a huge deal really, but I think I'm just going to go for the 27.5 34mm option and enjoy not having any hassles.
Discussion Starter · #3 ·
I already have this fork it came on my Mojo HD, which is why I am trying to find out if the 650b wheels will fit on it.
hi Nate,
after looking at some pictures I see that F34 has o lot of clearance with 26" tires, we all also know that even f32 cleared 650b tires. I can assume that f34 will take 650b tire with no problem... but when you have a fork already measure it - from axle to arch. 650b tire is 700-710mm tall, right?
Add roughly another 1cm (~1/2") for mud and it should be fine.
BTW. if someone can help with a real picture I would be also pleased ;)
Subscribed...
That being said I'd be totally shocked if there was any arch clearance issues since the 32 series clears even the tallest 650B tires by about 3mm. I'd say to let all the air out with your 26" wheels on and slam the fork to the bottom and see how much clearance you get to the bottom of the crown. Your looking for at least 12.5-13mm but hopefully more like 15mm+.
The 34 fork has a 7mm greater A/C height than the 32 fork (26" versions) so I'm thinking for at least most tires it should be a go. Still, get that measurement.
WebHelp
Discussion Starter · #7 ·
Bicycle accessory Bicycle part Carbon Bicycle tire Synthetic rubber
hi Nate,
BTW. if someone can help with a real picture I would be also pleased ;)[/QUOTE
Discussion Starter · #8 ·
hi Nate,
Thats a 2.35 Hans Damph on a P35. The clearance there is about 3/8".
Discussion Starter · #9 ·
hi Nate,
Axle to bottom of arch I'm getting about 35.5cm.
Subscribed...
WebHelp
Didn't they flatten the arch design on these new generation 34mm forks?. If they did , the cynic in me would say that the changes came about to force people to use the official 650B fork. I suspect however it may have been to tweak up the stiffness , especially since they have dropped the weights of the forks yet again.
Note the new arch design in these pics, it's quite different.
FOX 2013: New CTD Damper, 34 Forks And More - BikeRadar
Jeez, didn't realize that so you could very well be right. Quite different in the arch area for sure vs previous years.
Guess we need someone to actually try it and see.
Aren't the fork offsets different angles on these forks as well?
In theory the 34mm 650b float should have more offset?Fox have taken their drawings off their site. I believe the 29er 34mm Floats have been pushed up to 52mm offset? One review of the 34mm 26" 160mm Float said it's offset was similar the 32mm floats. The 36mm Float used to have an odd ball 37mm offset.
My 55 CR has a 44mm offset which makes it still steer well with a 650B up front.
1 - 20 of 20 Posts
