1 - 12 of 12 Posts
Just came from the dealer who showed me a 2013 Trek Superfly Comp for a good price. He has no concerns about a 6'4" 250lb guy riding a Carbon Hardtail. The trails in my area area can be full of roots and rocks, but I am not jumping off things. Any concerns?
Since I know someone is going to ask, "Why a hardtail, given the conditions I described"... Given my limited price range, I would rather spend the $$ on components. Also, concerned about the linkage of a lower-end FS, given my weight and price limit.
Thanks.
I have used a mix of carbon and aluminum bike parts for years and I've broken more aluminum parts than carbon. I think you should be fine. I could be wrong, but I believe Trek does a lifetime warranty on their frames.
I bought a specialized 2014 carbon comp, and in the weight limit is listed at 275 lbs.
You can find Specialized weights if you google this file name
"0000037057_r1.pdf specialized"
Vassago Bandersnatch, Motobecane HAL Comp 27.5+
I'd be more concerned with the wheelset than the frame, the Mustangs are not a good clyde rim. The frame will be fine, just trade those wheels out for something stronger.
I personally would do a steel hardtail ANY DAY over a carbon.
I crash and am rough on bikes, and wouldn't want to worry about banging it off a rock.
If it were my money, I would buy a bad ass steel frame and dump a bunch of money into wheels, a fork, and a strong crankset.
To my knowledge, there are a few manufacturers that actually give you recommended rider weight max's. Being 6'2 245#, I have talked to several manufacturers that I have contacts with. And I was told that I would be towards the upper limits of what the bikes were intended for. However, that doesn't mean the frame will fail, or that I couldn't ride carbon. I was also told that if there ever was an issue, it would be replaced. I've seen plenty of frames fail and the riders were less than 200#. It just depends on the terrain and the situation.
Santa Cruz openly advertises there are no weight limits on their carbon frames.
I can say that so far, the only company that publicly
Just curious... if carbon is supposed to be stronger, why is the max weight LESS for the carbon model of the same bike?
Carbon has a higher strength to weight ratio, but using carbon as a material doesn't just inherently make a bike stronger and lighter. How it is built and how much material is the main factor just as it is with any other material. You could make a carbon frame that would have a 500# weight limit if you wanted, but the manufacturer decided to put a (conservative) 275# limit based on the amount of material and the design of the frame.
1 - 12 of 12 Posts
