What size is your chain ring? You could go with a smaller cog in the rear and a larger gear in the front.
Did you run the new cog with an old chain? If so, how old was the chain?bikeny said:I use a 24t cog for my preferred SS gearing. I have been very happily using a Boone cog, and it has been great. But I am starting to fear the day it wears out, as I cannot get another one. Yes I have tried all the available channels. So I was doing a search and came up with 2 companies making 24t SS cogs, Endless and Rennen. Both are made from 7075-T6 aluminum. I REALLY don't like the idea of aluminum for a SS cog, and would rather have steel or titanium. I tried a 22t Endless for a couple of rides a few years ago, and the teeth showed significant mushrooming. I am not a huge clyde (185lbs), and I don't think I have superhuman leg stregth, so I am not sure what to make of this. I have seen plenty of reviews from people happily using Endless cogs, even in smaller sizes. Did I just get a bad cog? That experience just has me scared about trying another aluminum cog.
Anyway, does anyone have any recommendations for me?
Thanks,
mark
I believe you mean smaller rear cog and smaller chainring...Vtolds said:What size is your chain ring? You could go with a smaller cog in the rear and a larger gear in the front.
Do you mean smaller in the rear and the front?Vtolds said:What size is your chain ring? You could go with a smaller cog in the rear and a larger gear in the front.
I have been running Endless Kick A$$ cogs on a few of my bikes for the last 3 years,,,,,,,,,,,,they have held up fine, but the largest cog has been a 21. I would guess a few of my 20's have at least 2000 miles on them and are still in fine condition:thumbsup:
That is the cog I mentioned in my original post, and they don't have any in stock anyway.sunset1123 said:I have not used these, but they are available as big as 25T! (alu though) -- https://www.universalcycles.com/shopping/product_details.php?id=22628&category=40
And no, I don't want a smaller chainring, especially that one! Then I would just have to replace the ring and cogs more often!sunset1123 said:edit: or you could go with -- https://sales.light-bikes.com/extralite/images/OctaRamp30T.jpg
SPICER Cycles had those.kdiddy said:I've seen a cog that mounts a granny gear chain ring to it, so the cog essentially is just a splined hub with a 4 bolt hole pattern. You could use any 24T granny gear that you want with that. I can't remember where i saw it or what it was, but it would do what you want.
Well, I'm no great SS rider, but I play one on TV (and I slept at a Holiday Inn).bikeny said:I REALLY don't like the idea of aluminum for a SS cog, and would rather have steel or titanium. I tried a 22t Endless for a couple of rides a few years ago, and the teeth showed significant mushrooming. I am not a huge clyde (185lbs), and I don't think I have superhuman leg stregth, so I am not sure what to make of this. I have seen plenty of reviews from people happily using Endless cogs, even in smaller sizes. Did I just get a bad cog? That experience just has me scared about trying another aluminum cog.
