2022 Scott Spark Evo
8338 Views 15 Replies 10 Participants Last post by  filip.orsztynowicz
I've made some good progress on making my 2022 Scott Spark 910 into what I'm calling a Spark Evo. Kazimer's Pinkbike review made some good points about the bike and got me thinking how I could push it a bit more into to the “downcountry” spectrum.
My first couple of rides on the Spark were a bit underwhelming. It was a bit sluggish and soft. Not what I was expecting from a bike which is 90% of a World Cup XC winner. It wasn't awful, but I expected a bit more pep from it.
My first upgrade was the bars. I’m used to 780mm from my old bike and run that width on my Pyga Hyrax as well. That done, the bike felt a lot more like home and I started to feel like I could get a bit more aggressive on trail with it.
Next on the list was a set of wheels. The stock Syncros wheels and Formula hubs were heavy (2100 grams) and had tragic hub engagement (20 degrees odd). Both issues were remedied with a set of Lyne Amp carbon wheels. They knocked 400 grams off the weight of the wheels and the 2.5 degree hub engagement is much more to my liking. I also added a CSixx tyre insert in the rear for a bit of insurance with a small 100 gram weight penalty. I also swapped out the Shimano brake rotors for some SRAM Centreline rotors, which seem to pair well with the stock sintered pads and give a lot more bite and stopping power. With the wheels done, the bike suddenly had that snap under power I was looking for.
Stock, the bike has a 125mm Fox Transfer, which was not enough drop IMO. I moved it on and fitted a OneUp 150mm dropper. The OneUp was the only post short enough to allow me to get my correct saddle height as the frame has a stopper to prevent more than 175mm of insertion. One of the downsides of the shock integration.
Then came the big change. The Twinlock was removed! I’ve got a few reasons for removing it, but honestly, the ergonomics of the latest effort from Scott are tragic. I could never get it setup that I could activate the modes without moving my hand on the bar. I’d also find myself activating the suspension lock when I was going for the dropper. Sorry Scott, not good enough. I was a little worried, the bike would be a bobbing mess at the rear without the Twinlock, but this is not the case. I set the shock up with 22% sag and it felt very supportive whilst climbing and did not give me the impression of being the slightest bit lazy. I also set a few PRs on a local trail I’ve ridden many, many times both climbing and descending.
So far I am very happy with my Spark Evo. Next up I’d like to get hold of a Grip2 damper for the fork and I’ll probably call it job done!
Bicycle Tire Bicycles--Equipment and supplies Plant Wheel
Tire Bicycle Wheel Bicycles--Equipment and supplies Bicycle wheel
Bicycle Bicycles--Equipment and supplies Plant Bicycle frame Tire
  • Like
Reactions: 1
1 - 16 of 16 Posts
Those are the syncros Silverton 2.0 wheels? So the synros hubs are rebranded formula hubs?
That is correct
  • Like
Reactions: 1
Hi, I see you removed the twinloc lever, is it the version with 3 levers?
Would you be interested in selling it to me as I would like to upgrade to the 3 lever (mine doesn't come with the dropper post so there's no 3rd lever).
Just let me know...
Just let me know...
I'm going to hold onto the levers for now. Your local Scott dealer should be able to help you with a set
That is correct
Typically the higher end Syncros wheelsets' hubs have DT Swiss internals. I think my wife's Syncros-branded OEM wheels on here hybrid say Formula.
Gotta make that price point somehow.
how is the fork holding up on longer downhills?
or would you recommend upgrading to a Pike
The FIT4 damper isn't great. I'd suggest an upgrade to a Grip or Grip2 damper as a more cost effective upgrade. If you are a heavier rider and or want a stiffer fork, a Pike would be a great option.
  • Like
Reactions: 1
Hi,
A lot late to the party it seems but hoping you could offer some insight. I'm torn between the Spark 910 and the Top Fuel 9.8. I already have Trance Advanced 0 with 145mm rear travel and 160mm fork (also sometimes switch out the air shaft for 140mm when I feel the urge) and that's the one reason I'm leaning towards the Spark. My thinking is that a lighter bike with shorter travel will inject some fun into the mellower trails I'm riding at the moment because the Trance is honestly too much bike for where I live now. . . Plus I could get back into some stage racing. What turned you off the Spark, and what aspects (if any) did you like?
what do you prefer about the Top Fuel, and what do you not like about it?
thanks in advance,
Martin
Does anyone has a 910 2022? mine came with 2 piston brakes XT, and the original specs said 4 piston. The Scott site changed, but if you look all over the net, all reviews and original specs appears with 4 pistons.
The hole 900s line comes with 4 piston brakes, and the 910 is near the top specs and made this, something that specialized will never do.
Given the recent supply chain issues in every industry, and that MFRs reserve the right to make running changes on specs (says so in fine print), at least they're shipping product.
They probably didn't want to, but you do what you have to in order to get stuff in dealers' shops and buyers' garages.
Annoying, perhaps, but at least you have a new bike. Lots of folks don't, and won't any time soon.
I’ve built up my alloy bike with all upgraded parts. Twin lock is off. Hoping to get a better shock than the X-Fusion squishy that’s on the back. Right now bars are at 765mm but I’m going to go down to 750mm to see what it feels like. I am also considering trying a 140mm fork up front.
Bicycle Tire Bicycles--Equipment and supplies Plant Bicycle wheel
Bicycle Bicycles--Equipment and supplies Wheel Bicycle wheel rim Tire
I have one and it came 4 pistons.
I find this hard to believe. The lockout is one of the best things about the bike!
  • Like
Reactions: 1
I absolutely agree, however my bike came with Ispec II brake levers and I want to replace them with XT8100 which is Spec EV. I need the EV adapter for twin lock lever and have no idea where to get it.🤷‍♂️ I was surprise to see Ispec II on a 2022 brand new bike :(
1 - 16 of 16 Posts
