Do they even make a Fox 1 1/8th steerer or is your bike one of the ealry "Taper Steerer" converts?
Yeah it is tapered.Do they even make a Fox 1 1/8th steerer or is your bike one of the ealry "Taper Steerer" converts?
Yeah it is tapered.
Yeah I'm mostly concerned about holding a line and since I'm 200lbs the 32 has to be run pretty stiff to remain supportive.
I made a swap from a 2005/6 Fox 140mm RLC (air) to a 2021 Fox 140mm Rhythm although on different bikes.
To be honest I felt the older Fox was a tad plusher, however it was also less supportive and super flexy when compared to
the newer Fork.
Get a 34! It will be a significant upgrade in stiffness and performance, not to mention comfort and fun.Yeah I'm mostly concerned about holding a line and since I'm 200lbs the 32 has to be run pretty stiff to remain supportive.
I moved from a 2018 32 SC Factory FIT4 to a 2022 34 SC Factory FIT4 on my singlespeed HT and found it to be pretty nice improvement. It had to play with air pressure to get to use the full 120 travel vs 100 of the 32SC, but it was better by a long shot. The biggest benefit was in fact holding a line when cornering as the 34 was more stable and predictable. Throw the bike in rocky corner and front end just tracks the line and stick. The 32 would be less predictable. I can't imagine how much better the 2022 will be over the 2010. Lots of improvements over the years. I personally think the 2022 34SC is a gem. I ride rocky XC trails in Arizona with the bike and do some racing on it.
