Brand new Diamondback Release 5C XL frame. Fit just wasn’t quite right for me. Will add photos later. Local pickup or Will ship to lower 48 for $200. That will include $5000 in insurance. For an extra $200 I will throw in a pair of Maxxis minion DHF 2.4 and DHR 2.5 tires with less than 10 miles on them, and a pair of unused cushcore 27.5 tire inserts. Let me know!
Full Specs:
  • FRAMECarbon Release 27.5, Monocoque Carbon Front and Rear Triangle, 130mm Travel, Level Link Suspension Platform, Euro Standard Threaded BB, ISCG-05 Tabs, Boost 148x12mm Maxle Drop Out, 1.5" Tapered Headtube, Post Mount Disc Tabs
  • REAR SHOCKFox Performance Elite Float DPX2, 3 Position Lever w/Open Mode Adjust, LV EVOL, 200x57mm, 22.2mm Eyelet Width
  • FORKFox 36 Performance Elite Float, 27.5", 150mm Travel, Fit4, 3 Position Dampener, Rebound Adjust, 1.5" Tapered Steerer, 110x15mm Thru-axle
  • HEADSETFSA No. 57 Sealed Cartridge
  • CRANKSSRAM Descendant 7K Eagle w/32T Direct Mount
  • BOTTOM BRACKETSRAM DUB Outboard Bearing
  • FRONT DERAILLEURMRP XCG V2 Aluminum Bash Guard, 32T, ISCG-05
  • REAR DERAILLEURSRAM GX Eagle, 12 Speed
  • SHIFTERSRAM GX Eagle, 12 Speed
  • COGSETSRAM XG-1275 Eagle, 12 Speed, 10-50T
  • CHAINSRAM GX Eagle, 12 Speed
  • FRONT HUBNovatec XD641, 28h Aluminum110x15mm Boost Thru-axle, Sealed Cartridge Bearing
  • REAR HUBNovatec XD642, 28h Aluminum Boost 148x12mm Thru-axle, 4 Sealed Cartridge Bearing, w/CNC Disc Mount, XD Cassette Body
  • SPOKES2.0/1.8/2.0 Butted Stainless Steel
  • RIMSe*thirteen LG1 EN Plus, w/TRS Plus Aluminum 27.5", 30mm internal width, 28h
  • TIRESe*thirteen TRS Race SS 2.35 Tire Tubeless Ready Single Ply Apex Aramid Reinforced, Slow Rebound, Dual Compound
  • BRAKE LEVERSSRAM G2 RS
  • PEDALSDB CNC Platform, Sealed Cartidge Bearing w/Replaceable Pins
  • HANDLEBARRace Face Turbine R, 780mm Wide, 20mm Rise, 35mm Bar Bore
  • GRIPSErgon GE10 Evo Lock-On
  • STEMRace Face Æffect R 35, 40mm Reach, 35mm Bar Bore
  • SEATWTB Volt Chromoly SL
  • SEATPOSTKS LEV Integra Internal Dropper, w/SouthPaw Remote, 31.6mm
  • EXTRASTool Kit, DB Shock Pump, Tubeless Valves, DB Mud Guard, Chainstay Protector, Carbon Paste
  • BRAKESSRAM G2 RS, 4 Piston, Hydraulic Disc, w/180mm Front / 180mm Rear Centerline Rotors
