1 - 20 of 134 Posts
Discussion Starter #1
Hey guys! What new bikes do you think will be introduced for 2021 and when do you think it'll be announced? Thank you!
SB120, Late July
sb115 DOWNCOUNTRY lightweight bike
67.6-degree head angle
• 74.1- degree seat tube angle
• Threaded Switch Infinity Rails with locking
nuts for added security and stiffness
• Updated rocker link
• New roller bearing shock mount hardware
• Internal cable routing
• Integrated headset
• Designed for short offset fork
• 1x specific frame
• Uninterrupted seat tube
• Boost spacing
• In frame water bottle mount
• ISCG 05 chain guide
colors on the sb115 are anthracite, white and turquoise
NEW FOX dropper with shorter insertion at all lengths
• Small – 125mm (running change will start with
2020 post)
• Medium – 150mm
• Large & XL – 175mm
• NEW Cane Creek 110 headset for T3 kit
• NEW 10-52 cassette on all SRAM builds (running
change)
• Upgrades:
• NEW DT Swiss Carbon Wheels -
(Running change to launch August 4th and T -
Series only)
• AXS for SRAM drivetrain build kits
KIT HIGHLIGHTS
• FOX 34 130mm FIT4 fork
• DPS shock includes Fox’s outboard roller bearing
hardware on the shaft side to decrease friction
• 4 Piston brake calipers on all kits
• DHF 2.5/ Aggressor 2.3 EXO Tires
• 180 front and rear rotors
• 170mm cranks on all sizes
This bike will disappoint some people hoping for an all new bike. It's really a tweaked SB100 with the SI fixed. Same front tri
A fixed SI and new rear triangle would be a huge improvement over the current SB100.
(speaking as someone who currently is trying to get their frame warrantied :( )
Where is all the info coming from, has there been a release/leak somewhere?
2020 post)
• Medium – 150mm
change)
• Upgrades:
Series only)
KIT HIGHLIGHTS
The return of the SB4.5
1 - 20 of 134 Posts
