New vs old
They also lowered recommended torque by 10 inch lbs
i have a 2021 150mm transfer kashima with a failed upper clamp that i haven't warrantied/replaced yet that is for sale, lmk if you'd like to buy it & handle the warranty yourself. $150 not including cable/lever which i reused. can send pics if you want. 415.225.3494 mGood to know, because I was sure for 200 mm one, since it came out later than 100-175 mm, but not so sure for the rest.
Want to switch from my Rockshox Reverb 125 mm (came with my 2016 bike) to a 2021 Transfer 150 mm.
call fox racing USA customer service, they will give you an email address to which to send your seatpost serial # & they will mail you the revised part within a few days. Contact Fox | Official Site of Fox Racing USI have exactly the same problem With my upper clamp ..a crack after 2 weeks With a 2021 cube and factory fox transfert ...
Did you find a solution?
Close to 2mts on my Fox Transfer, no issues with the new clamp. I think they changed the torque from 8Nm to 5.1Nm.Has there been any problems in with the new clamp yet?
Make that 4... same issue hereFox needs to redesign the upper seat rail clamp so 1) it can be angled properly on all bikes, and 2) so that the front bolt hole/slot doesn't crack. I think the the cracking is happening because the front bolt head slips forward slightly and stresses the tip of that bolt hole/slot, depending on seat and seat tube angles.
Dear Fox Suspension - please make available soon a replacement upper seat rail clamp for the 2021 Fox Transfer seatpost. This is a relatively easy problem to solve without recalling anything.
I guess I would be the third guy now to report a cracked upper seat rail clamp in this forum? (Sorry I cross-posted, but others and Fox need to know about this.
2021 Fox Performance Elite Transfer Dropper Issue)
